Air Filter change - S2
- Thread starter xenon
Yup, badge panel has to come off.
Not difficult, but don't forget to remove the rubber strips from below the headlights and take the bolts behind them out. The panel itself is a bit wibbly-wobbly when not bolted on as well, so handle with slight care.
Once the panel is off, the filter change is very easy.
xenon
Peter Empson
I'm also running a MAF and have experienced no problems with the oil, and I've cleaned and reoiled my Green filter at least a couple of times since installation.
There's an interesting bit of PR from K&N here about the MAF problem: http://www.knfilters.com/news/news.aspx?ID=422
Best regards,
Peter
xenon
On removing the badge panel there are two 10mm (or may 8mm) hex-head screws that go through the very ends of the thin bits in front of the lights into the front wing as well as the ones you'll see when you take the rubber bits out.
