Hi,
Hope someone out there can help me. I have a 1988 944 Turbo and the air con is playing up.
If I set the dial to as cold as possible, the usual semi cold air will come out of the vents. If I then also press the Air Con button (which does light up), that same air turns red hot. Everything else stays as it was. If I then flick the air con switch off - it goes back to semi cold as I would expect. Anyone has this problem before or know what this means ?
Thanks guys.
GH.
Thanks guys.
GH.
