Just done my 968 - like you, first time I've done a brake fluid change on my Porsche.
If you haven't already got some clear plastic tubing, raid your local aero modelling shop for clear fuel tubing - the larger size (about 1/4" OD) is perfect, they sell it by the metre.
I bought ATE Blue from Euro car parts locally for about £13 - makes the changeout really easy as the colour change is obvious when the new fluid gets to the bleed pipe. They do the same fluid in gold colour - handy for next change!
11mm ring spanner for the bleed nipples - and as everyone says, a good soak in WD40.
Start with the rear nearside caliper, then rear offside. If you've got Brembo 4 pots like the 968, don't forget there are 2 bleed nipples per caliper - you have to do both!
I did mine with the wheels off, made access to the calipers easy.
From the 968UK forum, I've read that it's worth re-bleeding a week and a few miles after changing the fluid - not got there yet, still waiting for the new wear sensors to arrive then I'm changing front discs and pads and will re-bleed then.
