about replacing the wipers
maritimeblue911
I ordered replacement wipers from Design911 and was sent two identical Bosch blades.
However, the set currently on the car (also Bosch) has a driver’s side blade with an aero lip, while the passenger side does not.
Design911 were not aware of any aero-specific version, although I am fairly sure they supplied me with the correct type a few years ago.
I suspect someone here may know the correct spec or part number — any guidance much appreciated!
I did the same recently but rather than mess around I I clipped the spoiler from the old wiper and put it on the new one ! Very easy to do?
Well mine were Bosch and just clipped out ! I have a spoiler on each blade now ! Looks good and better rain clearance ?
Just looking at my photos again and I can see that my aero is part of the 'blade housing' so the only way that I can see to keep it would be to replace the actual rubber (and it's metal strips) ..which is not very appealing. Seems odd that Bosch would make this a few years ago but no more..?
I fit larger blades than Porsche reccomends...IIRC 19" on the front and 21" on the rear. You only need the aerofoil on the drivers side.
Pete
+1 for the larger size blades. Think I have 19"s on the front and 21" rear. Fronts are Bosch retro fit aero blades, no spoilers, work great.
Allow me to enlighten all!.... if you want Porsche quality wipers... for your Porsche... buy Heyner blades... then your wipers will match the rest of your car!!
Yup, replaced all mine with Bosch 19" on the front and 21" on the rear...the extra inch actually makes all the difference on the rear, said the actress to the Bishop.
