9x16 Fuchs - Where and how much?
- Thread starter Greg Park
How much - second mortgage territory.
Seriously though, these are very hard to get hold of. Try the specialists like Porsch-a-part and Jasmine, good ones in nice condition can fetch daft money, I've seen people asking four figure amounts. Keep an eye on eBay, they sometimes come up (both here and overseas). Might also be worth putting a wanted ad in Porsche Post and 911 & Porsche World.
Obviously they will beef up the aesthetics, but they won't make a nicer car.
Surely a man with Caterham experience knows never to 'over-tyre' a car?
Recommend 6s&7s (best IMO), 6s&8s or 7s&8s. Widening the track with spacers is another option.
http://www.early911.co.uk/html/fuchs_rims.html
Jamie
If the point is that wider wheels decrease the delicacy or adjustability of the car then that can really only be the case *if* you use wider tyres as well. I used 225/50 and 245/45 on 7/9s for years and felt this was a great combo for road and track use. I would suggest you try it before denouncing it. As our cars weigh circa 1300kg once fuelled up, this is not a massive increase in tyre compared with a Caterham at half the weight.
IMHO, even the optical benefits of using 7/8 or 7/9 make it worthwhile. I am not a big fan of the huge gap between wheel and wheelarch when running 225s on 7s in the rear. See below with 7/9s with 225/245 - with 14mm of spacers per side on the rear as well.
BTW, Jasmine had new 9s this time last year for not much more than the going rate for used.
http://www.porscheclubgbforum.com/tm.asp?m=109585&mpage=1&key=7x16𚵏
sheep911uk
LOVELY FUCHS 16 INCH ALLOYS 6 AND 7 JWITH CENTER CAPS GOOD TYRES AND LOCK NUTS
Item number: 4569571470
Anyway, when these wore out I changed to 225 x 50 x 16's on the rear and kept the fronts on 205's although I replaced these as they were not N1 compounds. Handling is fine now that they are worn in, but the set up is very susceptible to incorrect tyre pressures.
To keep the look at the back I have installed a 26mm German motorsport spacer, which recreates the wide look and fills out the arches nicely. Any thoughts on what spacers (if any) I should try on the front to achieve a similar affect without stuffing up the handling?
Answers on a postcard!
Steve
You can get away with more but you run the risk of fouling the guards. If I add up the extra track on my trackday set-up (7s and 9s with 225/245) compared with a std 6/7x16 set-up, it is 31mm per side on the front and 42mm per side on the rear with no clearance issues, however, that's with stiff torsion bars, lots of neg camber (2.0/2.5 degrees) and rolled front arches - and its very tight. You do the math, that's about half way to std Turbo track widths all squished under narrow arches [
RB
Of course, you could use 7mm shims on the standard studs and nuts. This may be enough for you to be satisfied with the fronts as I think 15mm is all you will want at the front (not 25mm) and 7mm gets you half way there.
I think I will go the spacer root and take my time in sourcing some 8/9 as I've fitted new tyres to the rears to might as well get some use out of them
Keep a close eye on the clearance after install. If they are going to rub, they rub about an inch or so *above* the fender lip. So they clear the lip OK and you think everything is OK until you hear the rubbing and find the paint is burnt through from the heat! Been there, done that !
