9ff 944tt
- Thread starter 944Turbo
I knew they did the current range, but I had no idea they dabbled in previous models.
Do you have any more info? [8D]
ORIGINAL: Mark Bennett
Wow.
Glad you asked [
"We are finishing the car in the moment on the first dyno run we had around 370 HP. The standard gearbox has to changed so far that the connecting points have to be turned because the position the engine it self changed. The costs for a modification like this would be around 17.000,00 to 20.000,00 euro including installation and exhaust and full services of all gaskets. Let me know when you need more info.
The boost is around 0.9 bar for the 370HP. I am very sure that the turbo lag is much smaller than with a single turbo. I got to say that the car drives very clean with an very nice boost curve."
The pictures all came from 9ff with the exception of the front pic showing the bonnet so I guess they may have a solution for that soon. ( I actually quite like the hole but it wont be very practical in the winter)
Tony
ORIGINAL: 944Turbo
Glad you asked []
I didn't realise you were still posting [
Not cheap is it? [&:]
Nice though [8D]
Tony
eastendr
Ultimately none survived as the cost and complication killed them off. They didn't give any improved performance. Rather they produced a whole load of new problems such as engine bay space for all the additional pipework, problems balancing (dual parallel turbos), and the inordinate amount of time to get suitable spec turbos to work in tandom, only to find a cam change for example would need a re-think of the turbo's internals. Excessive under bonnet temperatures from the twin turbos is also a major problem and may well need a redesigned cooling system for oil, water and air management.
Tilting the engine away from it's 15 degrees will also raise the centre of gravity ... Is there sufficient room for the 9FF conversion on a RHD car (steering mechanicals in the way ?) etc.
Call me a dinosaur, but unless they can get a phenominal amount of torque improvement, reliable top end power and drivability, they won't shift many. And it's seriously expensive compared with what you could achieve by other methods.
It's obviously designed as a boost monster as they're using low compression pistons and relying on a lot of boost being available to make it drivable. Using a supercharger would be much better in that respect, but would loose the top end power as it will need to rev with the 16V head to make decent top end power.
It's all compromise. I still believe that the standard configuration can be made very acceptable with the right development.
Rick.
There is lots of stuff going on for a 15 to 21 year old car [
Tony
sawood12
I suppose the lower compression pistons are because they've based the project on a 16v S2 engine.
ORIGINAL: Hilux
OOOhhhh I love the wheels, they look like the ones on Ricks car??? What are they?
They are just the 18" 5-spoke carrera wheels off the 996/Boxster
Trust a Boxster owner to lay claim to something like that. [
While it is encouraging to see a reputable tuner doing work on a 944 as this may raise peoples perception (and the potential resale value) of the '44, I agree with Ricks view. Why?
I wait with baited breath to see how Tony is going to sell the idea of spending 20,000 Euros to Mrs 944Turbo; particularly for a power hike of 20 bhp on what he has currently. [
I appreciate that the more power you get the more additional power costs but that is pretty ridiculous.
They really need to sort out the bonnet situation though if they want to sell any, and is it just me but those turbos look pretty big anyways?
While I can see how a twin turbo would work on the Porsche 6 cylinder boxer engine - one turbo for three cylinders - I would have thought one turbo on two cylinders so close to the outlet would give a pulsed exhaust gas delivery which can't be ideal?
eastendr
ORIGINAL: Hilux
Mark, I believe the boxster versions are much narrower. Probably best to keep them as 'space saver spares'
ROFLMFARO [
(that'll teach you not to have bribed me with a pint last night at the Dysart [
eastendr
ORIGINAL: sawood12
The normally aspirated cars run a much higher compression ratio than turbos.
The more boost you want to run, the lower compression you have to go to beat detonation. Hence my assumption they're relying on a lot of boost available all the way through.
The other way is to keep a relatively high compression, but run a lower boost level, but rely on increased VE.
Rick.
