997 S PDK or 997 PDK
- Thread starter ach
adrian996
InnerSphere
To answer the original question, the only real difference is power. If you want more, get the Carrera S, if not, get the Carrera. The only way to answer this question is to drive the cars and decide which you prefer. No amount of theorising on a forum is ever going to really answer the question for you.
dereksharpuk
1. The engine is more modern with fewer parts, thus more reliable.
2. It is much more economical.
3. It creeps into a lower taxation bracket; my car is only £210 per year!
4. The engine sits lower and thus the stability should be better.
5. I don't need the extra power as the 3.6 produces just about as much as my old 997S and with PDK delivers it better.
6. The insurance is much lower, I pay less than £500 pa fully comprehensive protected ncb.
ach
I am going to try both next week. My personal feeling when I am looking at the specs of these two cars BEFORE I tried them is that they seam to be pretty close and at the moment I am thinking the way Derek has just explained.
I understand though that they may feel very different when driven... Will see
Ronnie C
ORIGINAL: dereksharpuk
Derek, are the engines in both the Carrera and Carrera S not new for the 997.2?
dereksharpuk
dereksharpuk
ORIGINAL: Ronnie C
Yes, both engines are of course new as they both have direct injection.
But the 3.8 is basically the old design, modified, whereas the 3.6 is totally new and will form the basis of all new boxer engines. Interestingly, the 3.8 still has the idler shaft which can give problems. On a recent trip to the Isle of Man a newish Boxster S suffer an idler shaft failure which resulted in requiring a complete new engine. The 3.6 does not have an idler shart and has many fewer parts.
dereksharpuk
ORIGINAL: adrian996
Hi Derek. What is the idler shaft and what does it do?
As I understand it, in simple terms this is a drive shaft for ancillery items such as valves. If the shaft breaks, valve(s) can hit the tops of the cylinders with catastrophic consequences.
i bet you still end up buying a 2S in 6 months anyway[ORIGINAL: dereksharpuk
I have tried both. I have gone for the smaller engine for the following reasons:
ORIGINAL: Ronnie C
Are you sure? From what I hear both the new engines ARE new. the 3.8 is now actually smaller than the old 3.8, so what is it based on if not new?
An idler shaft usually changes direction of rotation or is used to gear speed down. For instance the camshafts need to rotate at half the crankspeed and an idler can be used to arrange this, though gears are also often used.
First time I've heard valves referred to as 'ancilliary items!!
dereksharpuk
Your description of the layshaft is correct, but in my simple mind anything that is not crankshaft driven (ie the gearbox) is ancillery, though I suppose we should be pedantic and only include truely ancilleries such as oil & fuel pumps etc and not camshaft.
I have been told that the 3.6 is all new, whereas the 3.8 is not.
dereksharpuk
ORIGINAL: robert997
Steady on there ! I think both the new 3.6 and 3.8 are the new design, with the same features such as direct injection, and 40% fewer parts than the old flat-sixes. This time they're more or less identical, the only difference being the swept volume and the power output.
Rob, are you sure? I have told (& read) that only the 3.6 is brand new with many fewer parts. Moreover, Porsche tell me it is lower which suggests that it is not the same. Perhaps I should check. I have been wrong before [
john crannis
Having sold my 996 3.6 C4s was looking to place an order for a gen.2 Carrera S. but am not so shure now!
dereksharpuk
As previously stated, I am only repeating what I have read and been told. I may be wrong; certainly Rob thinks so. Either way, the 3.8 engine is, at the very least, much modified, in particular it has direct injection. I would most certainly go for the Gen 2 (I did [
