997 Diagnostic Computer Rev Ranges
- Thread starter jpbecker
ORIGINAL: jpbecker
Should I be concerned?
Depends what they mean! (did they not explain? - fact that they mentioned it implies that these number ranges are somehow beyond expectation).
Have a look at this thread: http://www.porscheclubgbforum.com/tm.asp?m=281708
Is your's a tip?
ORIGINAL: jpbecker
My car was hooked up to the diagnostic computer at my local OPC today. Can anyone tell me what 'range 1,2,3,4,5 and 6 mean? I have occurrences against 1,2 and 3 but nothing higher. Should I be concerned?
Number of ignitions, range 1-RPM Range 7,300-7,500
Number of ignitions, range 2-RPM Range 7,500-7,700
Number of ignitions, range 3-RPM Range 7,700-7,900
Number of ignitions, range 4-RPM Range 7,900-8,400 (Some damage)
Number of ignitions, range 5-RPM Range 8,400-9,500 (Damage)
Number of ignitions, range 6-RPM Range 9,500-11,000 (Damage)
ORIGINAL: garyw
The numbers could be high as its counts every firing of a plug...
7300rpm would be 121 per second
garyw
Actually I think it'll be 365 per second because I'm assuming that each rev fires 3 cylinders.
ORIGINAL: garyw
I'd suggest that it means your "trying very hard" []
Its just hitting the limiter and working as it should be...
I wouldn't really want to see my numbers []
garyw
Does the rev-limiter cut the fuel, or the ignition? Some how assumed it would be ignition (easier to implement), in which case I'd expect it to instantly lose power and revs would hardly (if at all) go over limit?
ORIGINAL: jpbecker
I think the previous owner may have change into 2nd rather than 4th at some stage causing the over rev
OK, but even at 365 ignitions per second means a minute or more of time at these revs to get a readout of "tens of thousands".
Anyway, it's well away from the "damage" range and I suspect these engines are well capable of the odd transgression. Porsche will set the red line at a level that allows the car to be driven hard long term while not creating warrenty costs for them!
Back on the car, I can understand excursions to the redline, its the Range 2s and 3s that annoy me!!!
There's a slo a place where the current number of operating hours and associated distance is logged. Unfortunaley on my 996 that does not correspond to the mileage indicated on the display, which is very annoying and confusing.
You need to know the when the rev limiter cuts in on a 997 C2 - presumably it's 7,300 (or maybe 7500?)?.
