996 targa mystery part
martyn.munro
I’ve had problems with my targa roof since I bought the car, press the button and it moves for 3 secs stops and then repress and it moves for 3 seconds again and repeat, I adapted and knew I’d sort it at some point, a fortnight ago it stayed open, so I followed lots of possible remedies and thought a good option was to replace the the rear window hatch lock micro switches, however, that didn’t cure the problem but I found another micro switch behind the lock bolted to the rail mech that moves the roof up and down, I tested the switch and it failed, so I tried a loop in the the connector and the roof went up fine. So I have a result but I can’t find the part listed anywhere other than in a workshop manual - any ideas? I’ll check with Porsche Guildford on Monday - but it’s nagging me now, so I thought I’d askIMG_0042.jpegIMG_0043.jpeg
Unfortunately, that’s the 3 micro switches in the hatch lock, I have them on order already - but I have found it and it doesn’t help that the numbers are very similar - it’s
996 613 221 00 - 19 in the diagram
Thanks it’s reassuring rose passion has a picture, although I’m in walking distance of Porsche Guildford so hopefully it will be cheaper there
