thirteeneast
potentiometers £450+ how can they get away with charging that for a large variable resistor?.
ORIGINAL: liam996
Not all what it seems apparently! The wiring is now faulty, 4 wires going to the throttle body should show 5 volts? One is showing 9 1/2 volts, so they assume is faulty and are now stripping the wire ans tracing it back to reapir. This in turn has now damaged 'apparently' the ECU (DME)!! And this now needs to be repaired or replaced! Anyone know somewhere i can have the DME checked by and independant so i know they are being upfront with me. I am confused as they have said so many things, thursday it "Definately wasn't" the DME as the donor vehicles DME didnt work in my car either. Now the donor vehicle is failing to start when the put the DME back into it! And it is my car that has caused that DME to fail also. All i know it will be 6 weeks on friday since i had my car ans it's really F@@@@@@ me off.
