993 windows keep steaming upwhen parked
- Thread starter sav993
sav993
but since i unblocked these its been ok no more water and dry. can it be blocked air filter not letting it breath.
SAV
JB 3.2
ORIGINAL: jboult
Check the carpets and more importantly the foam underlay beneath them to see if it's damp. The underlay alone can hold a huge amount of water (usual suspect).
After that, check the drain holes/tubes etc.
Cheers/John
Where are the drain holes/tubes located?
ORIGINAL: JB 3.2
ORIGINAL: jboult
Cheers/John
Was this referring to the sun roof drain holes (which, when clogged up, cause sun roof seepage to drain down into the car and soak the carpet)? There are two in the rear corners of the sunroof well that drain down inside the C pillars into the channel around the engine lid and two at the front (I believe but not seen these ones) that drain down to exit under the car behind the front wheels.
jboult
What Mark said for drain hole location for a coupé!
For the Targa, the chances are the rook is leaking slightly. This is a little more tricky to cure, so before you start dismantling, realigning, tightening, swearing/cursing the designer (aside - I really would like to meet the person who designed the roof and blind - they have to be extremely eccentric!), do a water test on the closed roof. A willing accomplice and a hosepipe is always good so you can sit inside and watch!. In reality most Targa roofs seem to let a little through, but it should be channeled onto the plastic roof trim that acts like a gutter and takes it away to the rear drain hole. If, like mine used to be, the leak is large, it seems to bypass the gutter and drip onto the carpets. The foam underlay acts like a huge sponge and you will suffer badly from condensation.
If the roof isn't leaking, and all the carpets and underlay are dry, then I'd start looking elsewhere for the problem.
Cheers/John
sav993
and underlay, wow sponge aint the word.so much water these are now drying indoors
wife not to happy but hey. re glued the joint hope it holds , if not would need a complete new door seal. hope this solves my problem will keep you all informed thanks for the advice guys.
p.s how do i put my car pics on this
SAV
ORIGINAL: sav993
SAV
Have a look at: http://www.porscheclubgbforum.com/tm.asp?m=330961
