993 Targa 'rim bolts'
- Thread starter AJOHND
And so the list of things to tidy up starts...
The rear O/S wheel rim bolts are corroded, presumably due to a previous refurb that wasn't finished and protected properly. The other wheels are all fine. Note, the bolts on all wheels are silver and not black!
Does anyone know if replacement rim bolts are available anywhere? I can't seem to find anything on Google. Besides the cosmetics, I am concerned the corrosion over time may become an issue for the integrity of the wheel. Any help would be appreciated!
Thanks,
Aaron
Cheers,
Aaron
In the meantime I have further associated rimbolt-related questions:
> is the shank diameter 8mm (M8 would be the technical reference) or M7?
> is the shank fully threaded, or is the area immediately below the head non-threaded (and if so, what is the measurement of this non-threaded area)?
With thanks for Members' ongoing interest,
John
I found this on Rennlist in my quest to find replacements. Drawn by someone who removed the bolts.
Let us know how you get on! We hope for the best!
Thanks,
Aaron
The manufacturing source can make - to special order - rimscrews which will exactly match the original spec.. I'm waiting to hear at what sort of cost/min order/timescales this might require. When all is all a little more 'definite' I shall advise further.
Cheers, John
My email address is ajdymond@btinternet.com - please send me a brief message and I'll reply 'off forum'.
Cheers, John
At this time, I haven't split my alloys for refurbing; I'm waiting to do so when I also need to replace the tyres.
Hope this helps, John
This is really useful. Inspired by your thread I'm about to embark on the same thing and so all advice is very welcome. The only difference is that I'm going for black nickel plating (again from Accu) just as a personal taste.
Did you find the original bolt material spec from porsche? I saw the other thread on torque settings, have you settled on 20nm?
Any other thoughts? Are the nuts nylock or loctited?
Our thinking was to replace the bolts one by one without splitting the wheels
Steve
