micksummer
Have been doing a bit of a search on here and Ph regarding 993RS tyre pressures on track and churned out some rather wide range of recommendations.
Just did a couple of trackdays with my RS, and was using my old trick of releasing the air out after a few laps so the hot pressure is the same as the recommended pressure, ie 36 front, 44 rear.
That however seems to be a bit high according to some of the threads. Does that mean there's even more grip than I had?
What are the general thoughts regarding track tyre pressures? considering my RS is a dentist spec standard model, now with road tyres, and later with Toyo?
