My 1997 993 C2S (67000 miles) has been unused for four years! It is currently with a Porsche specialist who found the discs need a little attention but surprisingly reports nothing else. With the exception of the usual service, what else should we do before I start to use it regularly again? Thanks in advance for sharing your knowledge and expertise
993 Refresh
- Thread starter Shapesman
Greenman986S
Change ALL fluids
Most things should be covered with a full service, fresh fuel and MOT test.
Also, check wiper blades as they harden with age and wipe the door / sunroof seals with Liqui Moly Rubber Care or similar.
Depending on how it was stored, may also need to check / spray electrical switches for damp ingress (common issue with the rotary headlight switch).
Door handle grease also dries out with age and non-use (easy to remove and lubricate).
