993 Rebuild help
Daylite
Hello everyone.
I have a LHD 993 C4 from 1995.
It has been in bits for quite some time while having paint work done. I am now trying to rebuild with little joy as I’m not even sure what I’m missing and where things go such as clips, trim, seals etc. is there a go to bible to assist with such a project? Or even better, are there any 993’s local to Ludlow, Shropshire that I could possibly look at and take pics? Any help would be hugely appreciated! Rob
I had a similar dilemma a few years ago when I rebuilt a totally dismantled Morgan from the ground up.
The solution was to buy another complete Morgan and sell that for a profit when I had used it as a template. Not as silly as it may sound? :)
Hi, Adrian Streather's book: 'Porsche 993 The essential companion' might cover some of the info you're looking for, but a guinea pig car sounds like an ideal solution - maybe find a club member and do a video walk-round their car? Good luck.
Also worth looking for Diy procedures on p-car.com and https://rennlist.com/forums/993-forum-58/ forums.
p-car has specific 993 diy step by step pictorial guides set out, as does rennlist, but you may have to search to find them as has a lot of 993 content.
Both are US based sites and centre around Lhd US spec cars, they often refer European 993 as ROW (rest of world) cars, there are subtle differences such as alarm systems, gearing etc...
Could I trouble you for more advice. I have discovered that I am missing a particular module from the frunk. I have no idea which one it is as it is missing. I also do not know if it needs to be coded to the car, if there are several part numbers associated with it or whether one size fits all. Picture attached ! Can anyone please tell me what the part circled is as this is missing from my car! Thank you in advance.
I believe that is the Bosch ABS or ABS-ABD module, depending on which 993 variant you own.
Looking again at the picture, with the red script that is an ABS-ABD module as fitted to C4, RS, Turbo & GT2. You can clearly see the brake accumulator, which is not fitted on a C2.
If you have a C2 it will likely be just an ABS module,
Thank you for the reply. My car is a straight C4 so my assumption will be that it is a straight Abs module that I am missing!
If you're sure?
I would look into it a little more, this article suggests ABD on a C4.
If anyone with a C4 could take a picture of their module for clarification.
It clearly says ABS or ABS-ABD on the module.
After much back and forth with my Porsche dealer, it seems there are a plethora of part numbers and a part specific Bosch number that will identify the correct fit for my car.
My vehicle is a C4 that was manufactured in 1994 and registered in 1995. If anybody has the same car and could take a picture of their module that would be greatly appreciated! Thanks in advance.
