992 Sport Design Package
MarkR-W
Hi,
Considering spec choices for a new 992 and wondered if the warning that comes with the Sport Design package 'Significantly Reduced approach/departure angle' has proved to be a problem with any owners who have it?
I only acquired my car in December and have not done a lot of mileage, but thus far have not encountered any issues: no issues with speed humps or the approaches to sloped driveways/entrances so far. The SD front spoiler is definitely deeper than standard so I am sure that there will be steep approaches that will prove a problem. Best thing is to approach anything you suspect may be an issue at an angle first time round and see how things go.
Like you, I tried to gauge others' experience of SD front end but found it hard to judge how it compares with regular front end. Overall, having read lots of posts, I came to the conclusion that whilst the approach angle is reduced (ground clearance not so much), no one really seemed to encounter any great issues.
I read somewhere that the plastic lip on the bottom of the front spoiler is both cheap and easily replaced though I can't find that post.
As an aside, if I were buying new I would not specify SPASM (-10mm) without the front axle lift to be on the safe side.
Your response is very timely as I’ve just posted a question about the same question. My main concern is Waitrose car park (other supermarkets are available) ramps to different levels…
Why not take a look at a car with it already fitted and judge how it may impact on your use? Maybe examine the splitter structure itself and see If it's one piece, in which case it will not be cheap to replace or maybe the drop section is separate and therefore be sacrificial. Alternatively, you could swallow hard and spec the front axle lift system too! ?
I had the sports aero kit on my 992 Turbo S with no front lift and had no problem during my 4 year ownership. However, the splitter is retractable on the TTS.
Regards,
Clive
My first 992 was a 2019 Carrera S Cabrio with didn't have the Sports Design pack but did have the -10mm suspension and therefore had the deeper front spoiler (see image). I had a lot of issues with it catching over speed bumps and especially the wide versions we had in our road entry. Ended up having two replacement lower lip attachments.
When I ordered my 992 Targa 4 GTS, I specified the Front lift, and that was very useful without problems.
My current 992 is a base Carrera with std suspension and no SD body option. I don't have any problems with that when going over speed bumps......
