Hi - Just upgraded from a Gen 1 to a Gen 2 Carrera. Car is fantastic. Trying to set up the Multi-function display (the car has a sport steering wheel with all the controls on it). Every time I set up the vehicle menu to show what I want (including units in psi not bar etc) it is ok until I turn off the ignition. When switching on again the display has reverted to factory settings again. The handbook is not a lot of help. Clearly I am doing something wrong and the info I select is not being stored. So much easier and simpler on the Gen 1 with a steering column stalk to set up the display and which stayed as wanted. Have tried doing it via the PCM display as well but the same thing happens. Can anybody help please. Thank you
991 Gen 2 Multi-Function Display setting up
- Thread starter DRDT
