991.2 software update due
- Thread starter bobnokes
Paul de Waal
Do you know if this is the same software as for the 991.1? Current version is 4.52, what version to you have on your 991.2?
What version do you have at the moment Bob?
new to Porsche and in particular use of forums.
I'm after a bit of help if possible, bought my new 911.2 in march this year, going to work this morning the coolant level warning indicator came on it asked me to stop the engine and top up.
i checked the level ,it was slightly low so topped it up and seams ok.
does anyone know of a cooling issue with this model its a 3.0s 911 carrera 4 s 2016 model
manythanks
Dave
I had an issue with my 991.1 and this was due to a vacuum pipe coming off the exhaust valve on the off side. This put the fault on cooling system warning on which had to be reset by the dealer. What I did experience before this was the coolant had been topped up too much and it blew the excess coolant out of the overflow valve and put the low coolant light on!. I cant say for sure but if the levels are ok and there are no leaks there are interconnected thermal protection devices on the car which can cause an apparently unrelated issue to be highlighted on the car.
If it does it again get it in for them to look at and check over for peace of mind matey
Paul de Waal
Would it not be nice if there was a list somewhere, with all the versions and their differences to see if it is worth it to spend that relative high upgrade costs. It is clearly a map update, but what else? Motor management firmware is critical to optimum performance nowadays...
Paul de Waal
Paul de Waal said:Correction on my previous message. All you have to press is INFO>OPTIONS>System Version (On screen). I have version 3.40 on my 991.1
Thanks for that, will check mine later.
BobNokes said:For anyone interested on my 991.2 the version software is MH12 ER POG11 P2144 0404
Thanks.
Is it possible to multi-quote?
