My 991 gen 2 Carrera 2S started smoking heavily at start up (white smoke), which is being caused by oil in the right hand turbo. I'm told that a common cause of the problem is that the original oil feed lines were a poor design and Porsche have since re-designed them and recommend fitting these whenever they replace a turbo on one of these cars. Can anyone confirm that this is actually the case and that it is a relatively common problem?
991.2 Carrera 2S Turbo Issue
- Thread starter TJH911991
Hi both my turbos went. Luckily replaced under warranty. Not sure how common it is.
If you look online this appears to be a common problem. Apparently there’s an issue with the oil feed pipe to one of the turbos, causing oil to back-up into the turbo unit. Oil remains in the unit rather than draining and burns-off at cold start causing the smoke.
It sounds as though the upgraded feed pipe is an essential fitment, especially when replacing a turbo [or turbos?].
Jeff
Jeff
