991.1 GTS, PSE, Exhaust Valves & Cargraphic
AMcTavish
Hi all,
Wondering if anyone can shed any light on how the exhaust valves work on the GTS when PSE is switched ON. Are they open at idle and then close briefly until 3500-4000rpm at which point they re-open? I have just bought a cargraphic valve controller which supposedly keeps the valves open "all the time", but other than a cold start I can hear absolutely zero difference between PSE being on and valve controller setting the valves to "always open". Any insight would be super helpful, as carpgrahic are not being :)
On the 911.1 GTS, The valves are closed regardless of engine speed. They only open if you manually select the valve to be open on the manual control button or when you select either sport or sport plus modes
