987 Sun Visor & iPod charger in centre console
justin.johnson
Hi all, picked up a 2008 987 yesterday, which I’m super pleased with. Its in great condition, just needs a few cosmetic bits sorting out,
- Drivers sun visor keeps dropping down! Anyone had a similar issue and any ideas on what hinge part is needed to replace, as it’s a bit annoying when you go over a bump and it drops down!
- and in the centre arm rest there’s an iPod/pad connector which looks to be factory fitted to the PCM and Bose system. Any ideas on what this does, guessing it’s an aux - there’s no reference to it in the PCM handbook? I’ve ordered an adapter in advance so it can connect to my phone to see, just thought I’d ask in advance, Thanks all :)image.jpg
Thanks Cliff! Appreciate the welcome :)
Our pleasure Justin .
Regards Sun visor you.might want to try eBay or a Porsche breakers for a little less expensive visor assuming in good condition.
Pretty common had this on a 986 kept dropping down .
Hope you get many miles and smiles.
We have a great technical team if support is needed.
Regards Cliff
- and in the centre arm rest there’s an iPod/pad connector which looks to be factory fitted to the PCM and Bose system. Any ideas on what this does, guessing it’s an aux - there’s no reference to it in the PCM handbook? I’ve ordered an adapter in advance so it can connect to my phone to see, just thought I’d ask in advance, Thanks all :)View attachment 5375
As others have said. That’s not factory. I would suggest tracing it to the head unit. It’s possible (likely) that previous owner had a 3rd party head unit in there and swapped it back when selling.
If you are going to try the adapter route then cheap eBay likely wont work. Later phones with lightning connectors only give digital sound. That ok out will expect analog sound. The apple adapters had a digital to analog converter in them but they didn’t make them anymore. You can pick them up from computer exchange.
There are other options but you need to know if that cable is connected to anything to figure out what they are.
Thanks for the advise, will aim to track the existing cable and see where the source is. Just tried an iPhone adapter on it to see if it would do anything on the PCM …. and nothing, so will look to get it removed.
If it turns out to be connected to something that speaks “iPod” (maybe one of those things that fakes being a cd auto changer - a dension for example) then have a look at a thing called a bovee or a generic 30 bin to Bluetooth adapter on Amazon
