987 S, 18" wheels vs 19" , some unexpected developments !
If there’s liquid in the spring perch I guess that a damper seal leaking is the most likely cause? If you jack-up the front end maybe you can reach in to the top of the damper to check?🤔
You could always try the “lean and release test” on the wing to gauge the damper’s effectiveness, but the suspension is so stiff that I doubt that you’ll get anywhere with that, so a damper replacement probably is your best course of action.
Hopefully the new wheels and tyres will go some way to address your ride issue.🤞
Even with my 15 stone on it, the dampers don't compress much :)
I also purchased a full set of 4 spring and damper assemblies from a lower mileage example (very cheap), will get a chance to take a proper look and assess them when I am next off work.
Might be worth fitting at least the front 2 as a comparison, doesn't look horrendously difficult according to the You Tube guides I have watched.
Bonus of fitting the whole assembly is no messing about with spring compressors either !
The 18's I am picking up are the same design as the 19's that are already fitted (Lobster claws ?), so hopefully should still look reasonable, even though they are smaller alloys and taller tyres to achieve the same 'overall' size.
My friend kindly travelled down to collect the wheels with my wife yesterday.
Not quite as described but seller is hopefully sorting a suitable price adjustment.
Busy today so not going to get chance to fit them.
The 18's are now on the car.
Much happier with the ride quality.
Might put new tyres on the 19's at some point, as an experiment to see how much of the problem was the 'elderly' rubber.
Next job is to get the used suspension set up cleaned up and fit the fronts,
Found more oily residue in the spring seat on the passenger side, so assuming that the damper is leaking.
One of the front top mounts on the used suspension I purchased was damaged, so decided to get a pair of new top mounts and dust cover plus bump stops.
Managed to purchase them all at very reasonable prices, including the top mount bearings.
Subsequently decided that I didn't want to mess about with spring compressors and dismantling used suspension.
So, everyone can point and laugh, but I have purchased a full set of the finest Chinese 'Bilstein copies' !
Came as a fully assembled set of front and rear dampers with springs, top mounts, etc.
For £460, with a 2 year guarantee and Ebay buyer protection, I had to give them a try.
Fitted the front ones today, need to do a few miles to see what my thoughts are.
It took me a long time, I am not a mechanic but can follow a good set of instructions.
Hardest jobs were torquing up everything to the correct figures.
The rears look like a complete pain to fit according to the You Tube videos that I have seen, removing a lot of interior trim to get to the top mount nuts and having to remove the driveshafts.
I need to think hard about whether I want to tackle the job myself.
I've had 19"and 18" on my Cayman and I prefer the 18" for touring around, both comfort and piece of mind. My Golf is on 19" and it recently cost me £700 in a new alloy due to a pothole. So yeah, the 18's are sensible, but the 19's look better in my opinion.
