Just finished fitting the passenger side regulator.
I replaced the driver's side a few years ago, but last weekend The Boss dropped her window down and was met with a shreek and a grind and a crunch and the window stopped dead, solid 3/4 down.
Stripped it all out and the failure was the same as the driver's side, rusted bowden cable.
Usual faff getting it all apart, clips, wire, more clips and more wires and 8 broken door card clips.
Disconnected the battery before dis-connecting the air bag gas cylinder.
Ordered a new one and 10 clips from Design911 and they arrived today.
Again, lots of messing about with ungainly parts, but all ok.
Astonishingly, the window glass aligned correctly and the drop on opening the door is a nice 12mm, far better than the driver's door!
However....
The on-shot to raise the glass does not work, ok if you hold the switch. One-shot down is good.
Have I missed something?
picture to brighten a dull thread!
However....
