987.1 misfire started this week
m300raj
Hi all just sharing my experience with this fault that started on Monday the car ran fine then suddenly engine management like came in and it’s was misfiring so I did a scan and it showed cylinder 3 misfiring so I ordered a new set of coil packs and spark plugs and had them fitted. It looked like they had never been changed car is running fine now so glad it was a simple fix see pictures of old coil packs.
Great to see a simple fix has worked!
As an aside (and maybe related to your other post on the fault you've got), I had an SL400 which was misfiring and an independent specialist and Mercedes themselves were left scratching their heads after changing plugs, flushing fuel lines etc. Eventually it was discovered to be a rotten earth connection. I was so fed up with it (took 6 months) I swapped it for my Boxster, don't regret a thing!
