Hi there, just become a member and keen to gain some advice on annual service. I bought a 2002 986s with full service history. Had the car 9 months and has only done 800 miles since I bought it, . It’s done 56000miles in total and just wondered what parts should be serviced at this mileage. Thanks
986 s 56000 mile service
- Thread starter Maricus
I believe the recommended schedule is every two years but at 20 years old i suspect there is some flexibility
Do you know when the following were last done?
Oil and filter - annual
Brake Fluid - every 2 years
Spark plugs - every 4 years
Air filter - every 4 years
Poly rib belt - every 4 years
Fuel Filter
coil packs should be checked as they can crack and cause poor running
Fuel Filter
Many thanks for your help it’s much appreciated. Yes oil and brake fluid was done in June 2023. Therefore will get the other things listed completed. Ps is the belt replacement you mentioned a big job and expense to do thanks David
My local Porsche Indy is £125
Porsche Boxster Servicing – Cotswold Porsche Specialists
cotswoldspecialists.co.uk
