Hi.
My Boxster S has suddenly developed a fault in that the engine does not respond to the throttle pedal.
The signal from the pedal goes from 0 to 100 so assume that is ok.
The throttle body is clean but does not calibrate when the ignition is switch d on and does not move when the throttle pedal is pushed.
Am I correct to assume this means a new throttle body is required or could it be something else.
Also is there anywhere that reconditions the electrics on throttle bodies as it appears that everything comes as one unit.
Any help will be much appreciated.
Thanks.
Thanks.
