968 Teardrops I have broken it
- Thread starter Lemon
berg944
My lux did this because it had not been tightened properly, because it needs a socket.
How do you get a socket on it when the loom goes through the middle.......
If you come round I will show you.
Mike
Lemon
ORIGINAL: berg944
It might be the nut come off the bottom, it is under tension from the spring.
Mike
Cheers Mike
When you around
Lemon
I have had to order new bolts and the washers that allow it all to move freely which were missing, which is why it all popped off.
Has anybody effectively managed to get the spring compressed to reseat the mirror housing onto the bases.
Any tips? Or is it just brute force. You had better eat some extra weetabix this week Mike [
Any help appreciated
hotblack944
Have a look here.ORIGINAL: Lemon
tim_haskins
hotblack944
Reading all that, putting the 14mm hex head in the vice, pushing and twisting sounds much simpler. The spring is pretty strong though...
Lemon
ORIGINAL: hotblack944
I found all the bits at B'n'Q, except for the #0 screw eye. I substituted this with a towel rail bracket which was a tad small in diameter, until I Dremeled a cut in it and bent it open a tad (this helps anyway as you can then see inside how far the spring is compressed). I also had to grind a bit off the nut so it would fit inside one of the mirror housings. I then had to cut a nut in half (to make a thin nut) so it would fit in the other mirror housing (the mirror carriers were slightly different).
Cheers for pointing me in right direction to web page.
Mirror back together with new washers which were missing and new bolt.
Now spins freely without pinging off.
hotblack944
Lemon
So.... how did you get it back together again?
Used the threaded bar with different size washers as per the web page you sent.
Compressed spring slight turn of whole assembly and it popped back into place.[
Got new bolts and washers for other side as I am guessing the same will happen to that side too, but I will wait for a day when I am truelly bored for that one.
