968 gearbox replace or repair???
- Thread starter Guest
ianreeves
Check out www.968uk.com for lots of info.
Its about £800 - £ 1000 for this work, Jaz in Wembly are masters at this, give them a call !
paulf968
Nb on different occasions had pinion bearings and rear wheel bearings go on my car in 4 years of ownership - so have become a reluctant expert!
ps if it is the box, repair is really the only option, new ones are silly prices and a 2nd hand one might harbour problems.
ORIGINAL: glenncoulterlbipp
Hi guys
looking at an 968 but it has a gearbox/diff whine does anyone have any info/prices on replacing the box or repairing it
Hi - had mine rebuilt last year (late) by Mike Bainbridge in Kendal - top, top chap. Worth thinking about doing the clutch at the same time, and if you're interested in a limited slip diff that would be the time to do it.
I priced gearboxes at the time and the second hand ones that I saw started at £500 - then if you wanted to make sure you didn't have the same problem (typically pinion bearings) you'd need to have the work done anyway.
With mine it was both the diff ("Fraser, second worst one I've ever seen") and the pinion bearing.
atb, and good luck
Fraser.
sawood12
I have decided to follow you to Mike Bainbridge, but as its so far from me (300 miles) I'm thinking of sending him the gearbox. Do you or anyone else, know what one of these gearboxes weigh, so I can get a shipping cost? Which delivery company would be best, any ideas?
Many thanks
John
If anyone else is sure of a number (weight), chip in. Delivery each way for me was in the order of £50.
I was put in touch with Mr Bainbridge by PJS here - Mike took loads of pictures before, during and after, so you'll have lots of stuff to stick in your service folder.
atb
Fraser
ps - if you want to discuss let me know and I'll get my phone number to you.
This was at Precision Engine Services in Inverness who are very good. But Istill reckon there is nothing sinister to stop any reputable engineering shop from rebuilding these.
In fact are these boxes not just VAG units with diferent ratios?
Their address is:
Garrard Way
Telford Industrial Estate
Kettering
Northants
NN16 8TD
Tel: 01536 517764
Now I can enjoy the dry weather with the hood down
