968 Club Sport at long last
- Thread starter Guest
Your list of faults seem minor and very typical so nothing to worry unduly about, and something to get your teeth into over the next few weeks making her perfect [
For the hatch rattle take a look at these two threads in the 944 forum:
http://www.porscheclubgbforum.com/tm.asp?m=37863&mpage=1&key=rattle鏧
http://www.porscheclubgbforum.com/tm.asp?m=36239&mpage=1&key=hatch酹
If everything is adjusted correctly and it still rattles I would recommend a new tailgate seal (£29 from Porscheshop). That finally cured my rattle, the old one was so flat in comparison to the new springy rubber one
Now for the big stuff, I noticed that when I switched on the fan and A/C this morning the belts started to slip, no worries thought I a quick nip and tuck of the adjuster and away we go. Anyway whilst under the front trying to get access to the adjuster I noticed a wet patch Oh No!!! [:-] It seems to be coming from the power steering pump and I've noticed the level is down in the reservoir, and the belts are damp with residue so looks like this will be the first major job.
Anyway back to the good stuff, I took my brother out today for a spin, cold sunny and dry [8D] perfect conditions for some handling tests. WOW what can I say, pushing her hard around roundabouts the grip is phenomenal very hard to lose the rear end. My Brother was very impressed with the stance of the car at speed even to a point where he admitted it would outperform his E36 M3 (another German Left hooker). He was amazed at the pull of the 4 port motor right up thro' the gears. The more I drive it the more in love I become it really does drive as good as it looks once you get the feel of it, trackdays will certainly be good fun.
Final note I'm now more certain its had a respray, I found a small run on the back vertical edge of the front wing, but other than that its been done very well. I just hope its as good as it looks, only time will tell.
Mike[
John H
I have since read that it is a difficult job to split the pump, but I watched them do it, and it looked OK to me. Make sure you check and tighten all the pipe joints before you tackle the pump, as they are prone to leaking.
JH
Busy weekend coming up I reckon.[
paulf968
A note about removing the pads on 968's if you are planning a quick clean & inspect. Coincidentally, just did my own rear brakes yesterday -- all OK, with no ally corrosion behind the s'steel plates, just clagged up with dust.
On the back of each pad should be stuck a pair of mushroom shaped spring things which locate into the pistons (they are supposed to stop squeeky noises). With these in place it is not possible (without aggro) to slide the pads out from the rear of the caliper when in-situ. NB Some garages do not bother to put these spring things back when changing pads so they may be missing.
IMO by far the best way is to go direct to removing the whole caliper, even though a few extra minutes will be required for detaching them & bleeding. You can then remove the pads, clean it all up on the bench, check the free movement of the pistons by hand etc and then re-assemble it quickly. In the end does save time and a better job is achieved.
ps hope you do not think this is a case of teaching your grandmother to suck eggs !!!
byeeee
paul
John H
As to leaving them out? I'm of the view that they are there for a purpose, so I prefer to re-use them.
A great place for brake components is Brakes International. They do Jurid pads, and sell the warning wires cheaper than anyone in the UK.
http://www.brakesint.co.uk
John H
I tend to agree with you Paul it would be nice to drop the caliper off complete apart from I hate bleeding brakes[
Out of interest what are the 968's like to bleed out, the MG used to be a right pain in the bum.
Mike
If the power steering pump is the same as the 944 (and I believe it is), then it is a straight forward job to change the internal seals. 911 & Porsche World did a 'how to' guide last year (I can send you a scan). IIRC the seal kit is about £15.
Also check that the hose from the resrvoir is tight. I've heard of many leaks caused by an old hose clip, and it runs down the pipe to the pump.
paulf968
Bleeding the brakes has never been a problem for me on the 968 -- children make ideal brake pedal pushers !! The only extra hassle is that because of the orientation of the pistons there are 2 bleed valves per caliper. ( I assume it is the same on a CS as my coupe)
ps have done the braided flexible job using Goodridge hoses and used Castrol Response synthetic -- so we are both heading in the same direction.
paul
Anyhow a simple job as usual turned into an epic, the double ended adjuster of the power steering was snapped at the join between the thread and the eyelet, luckily I had one half rod left for my trusty Arc welder so once stripped off and cleaned I managed to weld it back together and get it all refitted and tensioned. Phew !!
I haven't found the source of the power steering fluid leak awkward to see anything in the dark, but I would say that the pump has been off recently as its too clean in comparison to the rest of the bottom end of the engine etc... pipes look OK but without stripping it all off its hard to say.
Also found some oil on the bottom of the engine, which again I can't pin down to any one particular area, but it seems to be coming from the right hand side up by the alternator bracket and running down to the front of the sump pan, its not a lot but enough to make me want to see where its coming from. Might have to be a strip of the top end at the weekend to pin it down as one of my pet hates is dripping oil.
So there you go the first installment of the oily bits to do list.
To be continued................................
minor problems at the moment so not too worried as long as I can keep on top of them, it has to be expected with an 11 year old motor. I bet your glad I bought this one now [
As for the MG thats in the Autotrader this week so everythings crossed for a quick sale. I need to cancel the insurance on it before the end of next week so I can send my new insurers proof of no claims, and also get a bit of cash back to pay for the immenant repair bills[&:].
Mike[
Don't be fooled by a high buy price it doesn't guarantee quality [
Mike
PS I'll probably eat my words in a few months when the gearbox drops off it [
You could also say 'don't be fooled by a bargain as theres no such thing'[
Thats especially true where Porsches are concerned....trust me!
