968 Belt Tensioner
- Thread starter marty
Chrishazle
Waylander
The tensioner is not part of the belt service and is not mentioned in the manual as a replaceable item, they last for ever if treated correctly, mine has done 170,000 miles and is working perfectly, I know of another that has not been replaced at 225,000 miles,
Saying that, the mounting pin for the lever arm, 944.105.170.05 has been updated 5 times due to breakages, this is worth replacing
they do get damaged by workshops that don't read the manual and stick them in a vice and crush the ends,
they are extremely difficult to get hold of second hand, I have contacted the original manufacturer AISIN in France and Japan,
they made an initial run of 15,000 for Porsche, then Porsche dropped the model and AISIN never made anymore, the moulds and process for them has been destroyed according to AISIN, there will be no more,
I have the emails if you wish to read them
mcgc0
Waylander said:Hi
Interesting.. What material is the tensioner made from?
Waylander
I have spoken to them directly and they made the original run for Porsche, and never made any more
there is a person on eBay that says he can refurbish a sealed unit for a lot of money, if the one the car is working then no need to replace
mcgc0
Thanks for extra information. Virtually impossible then to manufacture or fabricate and alternative or modify an old or non-functioning one..Waylander said:The tensioner is made of steel, and is a spring / hydraulic unit, made by Aisin
