964RS Engine
- Thread starter Guest
ORIGINAL: OllieW
Have you bought one yet...
Feroz is out the country for 3 weeks, should do the deal when he returns.
Dick
SimonExtreme
WHAT!!! Surely shome mishtake! What is he selling for?ORIGINAL: dick
ORIGINAL: OllieW
Dick
As to the original question, engines are normally not an issue and the same is true of gearboxes. The LSD plates do wear out, although I am not sure that its very expensive to sort out.
If you are buying Feroz's car, it is certainly well known and well looked after. Depending on who has been servicing it, you can probably get a good idea of what the car is like from the invoices. GT-One and Autofarm usually give fairly detailed reports on the current condition of the car when doing a service.
eastendr
SimonExtreme
You had me going for a moment! I was thinking "WTF" when I realsied when that was taken [ORIGINAL: eastendr
OPC, obviously []
http://www.cannell.co.uk/R20%20OPC%200706-5.htm
http://www.cannell.co.uk/R20%20OPC%200706-6.htm
Gearbox's are fairly durable but do wear out, syncros can go with higher milage and worn lsd are also common. The shift linkage can also wear causing a sloppy change. Clutch slave cylinders and clutch pedal assy can also create minor bother.
