edh
ORIGINAL: zcacogp
To the original poster: my S2 does around 15k miles a year on all roads and in all conditions. I can't think what I would ever replace it with....
I can [
ORIGINAL: zcacogp
ORIGINAL: zcacogp
To the original poster: my S2 does around 15k miles a year on all roads and in all conditions. I can't think what I would ever replace it with. They are simply superb cars for this sort of use.
I refer my learned friend to my earlier statement; it still applies. [ORIGINAL: edh
I can [ORIGINAL: zcacogp
Oli.][
] - just add boost [
ORIGINAL: gav_sw20
Am getting bored of my e46 323 coupe and want something a bit more fun to drive to work.
ORIGINAL: edh
I can [][
That's an interesting set of observations James. Thanks. When I bought my S2 I was sorely tempted by an E46 M3 as an alternative, and decided in favour of the 944. Your comparison suggests that I made the right choice. FWIW, the principle reason I chose as I did was because of the image of the BMW, particularly in the East End of London, where I live. However the other factors listed suggest I made the right choice for a number of reasons!ORIGINAL: James_G
.... my E46 has a few more horses, but it's anything but dull.
Anyway, if you're commited to a change then as you've heard the S2 can be easily pressed into regular service as a commuter. Personally that's not how I use it, and I far prefer driving my BMW (yes I know, I'm a heretic and must be burned) but I commuted in the S2 one day last week and other than getting a bit hot, all was absolutely fine.
Based on my experience then, an S2 will be:
Noisier
Have heavier steering
Use a touch more fuel
Hotter in summer
Less comfortable, ride wise
More aggro, as would any car that's going to be circa 8 yrs older than your current one.
Less sonerous, i.e. you'll miss that nice six cylinder BMW sound
However it will feel:
Lower and more sporty
Nicer going round corners (just)
A bit more special if you get a nice one
More connected through the touch points (or more seats of the pants)
And it will be:
More practical, load area wise
Probably about the £££ same to run
And you'll get let out of junctions more easily.[]
ORIGINAL: sawood12
Is the E46 the square nose one? If so they cost at least double to insure as a 944 Turbo, and the Evo's are even more. Also i'd say they are not as good a car as a turbo. Evo mag took one and spent about £10k - £15k on it, stripped it out, fitted a roll cage, race suspension, AP Racing brakes and did some other mods with the aim to break 8 minutes at the ring. Even with a proffessional driver at the wheel and many attempts it was only able to post a similar time to Davyboy in his near stock 944 Turbo on R spec tyres (I think Jon 'Suffolk944' has this car now). Dayvyboy is clearly a very accomplished driver, so assuming his driving skills are similar to the proffessional driver Evo mag employed then that says to me you need to spend upwards of £10k on an E46 M3 and strip it to the bone to make it as good as a near stock turbo with leather and A/C on R spec tyres.
