944S 16v into 944Lux/924S?
- Thread starter Lizard
You'd need the ecu & loom from the S but unless you already have all the bits (ie an S with a bad shell & a lux/924s with a bad engine) and want to mix & match why not just either buy a complete S or S2?. IMHO it's not enough of a step up to warrant the work involved if it's an upgrade - go for an S2 engine at least [
The 924 is lighter (a fair bit, i am given to believe), and more streamlined (less frontal area.)
Lali's 924 with a 968 engine in it (indeed, complete 968 running gear) ate 968's for breakfast, and came back for more.
Lizard, i don't know the answer to your question but do agree it's a good idea. A better idea would be to use the S2 engine, for reasons I am sure you will understand. In fact, if I was planning such a job you'd be one of the first people I'd eMail to ask for advice .... [&:]
FistsOfHam
....just saying
Northern924
Same reason I will probably never own an S, if I want to own something better than a 2.5v I'll take 3.0 S2 and nothing less Thank you
bertelli_1
