944 turbos
- Thread starter TISPKJ
Fat Albert
pauljmcnulty
Neil Haughey
968 tip has very similar straightline performance to a manual S2, both took about 15 s to the ton in contempory road tests.
pauljmcnulty
ORIGINAL: A9XXC
Traditional type of auto is available on all N/A engines - 2.5, 2.5 19v, 2.7 and 3.0
I've never heard of an auto on an S2? Might not be very nice on an S either!
Do know they did 2.5 and 2.7 ones !
George Elliott
no, thankfully.
The car was featured in, (actually started) the turbo Cup series as you may be aware, and auto transmission would have been considered inappropriate for the model.
regards
George
944t
bmnelsc
ORIGINAL: Neil Haughey
...and bigger inlet valves, different manifolds, MAF, newer gen ECU, forged rods, etc. Barry Hart has commented before that the varioram doesn't actually give more power it just moves it about a bit. Its a bit of an oddity of an engine and driveline package as despite having 6 tightly packed ratios compared to the S2's 5 (albeit barely any difference in 3rd and 4th), they also came up with an engine that has an even stronger spread of power than the S2.
...AND hydraulic timing belt tensioner - replaced the spring-loaded tensioner used on the S2....
Out of all that, I'm betting the ECU and MAF were responsible for most of the extra 28 HP although you have to think that vario cam permitted more radical cam profiles.....
Changed "Rubber-Duck" to one Tiptronic cab last winter. Was a nasty job to do. Won't do it again [
Factory had it's odd moment when they equipped 968 Tip with 944 manual bellhousing.... But i suppose they have pleeeeeenty of 944 automatic leftover parts available when they "designed" 968 Tiptronic. It is odd same damper was used with 240hp engine, when it was designed for 163 hp. Damper is the weakest part of Tiptronics.
Have you checked your "Rubber-Duck" lately? I suppose most of you will find signs, which eventually leads to this:
This tiny little thing is actually really good. A small cylinder filled with some kind of fluid and a spring. Japanese make nice parts [
Pretensioning Aisin made "hydraulic" tensioner
Just 8V 2,5 & 2,7 had autotrans available. Last model year 8V 2,7L was just a "savings model". Porsche spared some money when all N/A models shared the same 104mm bore block. They just had to make small change to cylinder head's front left corner.
Here's a factory new 2,7L head. Have several of them in my garage [
It's quite easy to modify a 2,5L head for a 104mm bore block
Here's what happens when you try to install either 2,7L or S2 head to 100mm bore block
Neil Haughey
