sawood12
I wouldn't say that there is any weakness in the engine of a turbo on the contrary, they are pretty bulletproof if well looked after. The thing about #4 cylinder is true but is usually attributed to poor bleeding of the engine coolant as there is a natural air-trap around cyl #4. If you bleed the engine properly then there is no increased risk.
You should approach a potential purchase of a turbo in exactly the same way as any other 944 - with caution. The engines on turbo's are pretty tough and this is borne out by many people running significantly increased levels of boost perfectly reliably at upto 350bhp on essentially a stock engine and by the number of people tracking them reliably. You should be more concerned about getting a car with good sills and the usual bodywork areas (as you unfortunately all too well know!). Clearly if the car is smoking like a chain smoker on a stressful day then steer clear - as you would with any car whether it be a turbo or not.
You can't judge how good a car is by how much the seller wants for it either. The best way to minimise the risks of buying a dog is to look for history - the more the better, anything that can indicate that the previous owners have treated the car as it should be treated. If you can find a car that has a full service history and other invoices/receipts to back up that work has been carried out when necessary then that all indicates the car has been cared for.
If you want to take a risk on a cheap turbo then fine, but you'll need to have money set asside, so if you can afford to have money set asside then why buy a cheap car over a slightly more expensive one with good history and in better nick? But for me the turbo is a superb model. The old school power delivery makes for an interesting drive and provides another dimension and the pace when on boost is exhilarating. All adds to the charm. I'll be sorry to see mine go.
