944 turbo weak brakes
- Thread starter Guest
These Brembo callipers suffer from 'plate lift', this means that the stainless steel plates that the pads slide on can lift away from the calliper causing them to pinch the pad and prevent proper movement. Places like www.rpmporsche.co.uk can overhaul the calliper for around £70
steve 944t
Hilux
my brakes are definatly poor boardering on the dangerous, you can push the pedel through the floor but it does not stop any better, if only they were as good as my dodge, cheers mark.
If I may say so....................
get off the road..................
Porsche brakes are not like that in fact no cars brakes are like that. What set up have you got? What pads?
