nicksonmsport
hi i currently own an s2, and just picked up an 86 turbo a few days ago which i have been using as a daily until the tax runs out at the end of the month.
it will then be stripped caged, buckets/harnesses suspension etc the car is going to be my track day car and a bit of advertising for the buisness
the car already has a boost enhancer and an amd chip and has rolling roads of 280bhp and 310 ft lb torque. although like always im after more !
i run a motorsport fabrication buisness so all work will be carried out by myself, we will start with the basics such as bigger intercooler, 3inch downpipe and custom exhaust, custom inlet pipes, induction filter and cold air feed etc but i just wanted some info from people with knowledge of the turbo engine and its strengths, weaknesses and areas that it responds well to tuning.
im used to tuning more modern turbo charged cars where some ecus will adapt air/fuel with extra boost up to a point, usuall being where larger injectors are needed and then its a case of custom ecu mapping.
how does the 944 turbo control its boost and air/fuel, i take it the amd chip takes car of extra fuel and air for increased boost?
if i wanted to increase the boost with a manual or electronic boost controller, then will the ecu/chip adapt and provide extra fuel?? or will it need a remap by the likes of chip wizards?
what sort of power/torque can be had from the std turbo and injectors with a boost increase and supporting mods listed above
i know a dual port wastegate is a good starting mod so will be fitting one.
whats the limit and the parts required to reach the limit on std turbo/injectors.
i would like to fit a larger turbo such as one of the lindsey racing items, and larger injectors so i can achieve over 400hp, but what would be required on the ecu side of things to support this. would i need standalone? or will a remap support this sort of power.
any ideas, info from people who have gone on the power hunt with a 944 turbo would be great.
many thanks
nick
many thanks
nick
