944 Turbo throttle pedal hitting the floor
- Thread starter midge
pauljmcnulty
ORIGINAL: midge
When i get in the 944 when you press the throttle pedal it goes to the floor and doesnt return without pulling it back up, anyone help me with the problem here?
Have you had the car jacked up recently? Very common for the floorpan to be bent by jacking up on the front point that's meant for a four-post lift. Solution is to take a lump hammer to the floor, and not to let a thick-fit fitter near the car.
I'd add a piece of 2x4 between hammer and the floor.
pauljmcnulty
ORIGINAL: midge
Ill have a look next time im at the car, so a good hammering from the inside should see it good?
Only if you've jacked the car up in the wrong place, or had someone else jack it up in the wrong place.
If you can't think how the floorpan could have been distorted just before the problem appeared then please don't start hammering the floor! [&:]
ORIGINAL: midge
, the floor doesnt appear to be dented at all
It's not something you can visibly spot as it is so slight.
I had to 'fix' mine last week after it had been jacked up on the front donut under the sill when the bodyshop put the wheels back on [8|]
A fairly gentle thump with a lump hammer on a thick piece of carpet at the base of the throttle is all you need.
