Over the cold period my 944 developed a bit of a tap.
It is possible it had always been there a little as I could sometimes hear a slight tappy noise when travelling in built up areas with windows down, but I thought it was either injector noise, or maybe the slight mainfold leak it has one on cylinder, but since then the noise has suddenly got a lot louder - sounding like a sticky lifter.
Just before winter I did an oil service and opted for a slightly thicker oil than what the previous owner was using as it used to burn a bit, so went for Total Quartz 10w50. During the cold weather I didn't use the car as reguarly as I had been, but when I did start using it again the tap was more pronounced.
As I say, to my ears, this sounds like a sticky/soft lifter, and if I listen with a stick I can hear it more clearly over the cam box at no. 2 cylinder. The noise doesn't seem to get any quieter when warm, and doesn't change with load or revs.
Here is a video:
<object type="application/x-shockwave-flash" width="400" height="225" data="https://www.flickr.com/apps/video/stewart.swf" classid="clsid
27CDB6E-AE6D-11cf-96B8-444553540000"><param name="flashvars" value="intl_lang=en-US&photo_secret=daeaf5fa4f&photo_id=17195211682&hd_default=false"></param><param name="movie" value="https://www.flickr.com/apps/video/stewart.swf"></param><param name="bgcolor" value="#000000"></param><param name="allowFullScreen" value="true"></param><embed type="application/x-shockwave-flash" src="https://www.flickr.com/apps/video/stewart.swf" bgcolor="#000000" allowfullscreen="true" flashvars="intl_lang=en-US&photo_secret=daeaf5fa4f&photo_id=17195211682&hd_default=false" width="400" height="225"></embed></object>
That didn't work, does this...?
https://www.flickr.com/gp/25266351@N06/8V9gXU
Assuming it is a noisy lifter, has anyone had any luck with these engine flushes?
I am always a little sceptical, and worried they would do more harm than good, but I know JMG recommend the Forte products, as does a local VAG/Porsche specialist. I had also considered dropping the oil and trying a thinner mineral oil to see if the tap clears, then refill with the thicker Total Quartz again.
Just considering what I can try before stripping down the cambox, as even then, if I do find a soft lifter or two, then from what I hear, the replacements are pretty poor quality anyway, and likely to fail pretty quickly?
Any suggestions or advice would be great
Here is a video:
