944 Turbo Tank range
- Thread starter craiginuk
George Elliott
70 constant is impossible where I live
George Elliott
George
944t
Simon when your off boost try and make sure the boost needle is near 0.4/6 rather then 0.8/1bar need to get mine adjusted but my afr change to 12.5 in 5th hard to mantane speed without sitting higher on the needle feel like there's more steady restance on the pedal here
ORIGINAL: 944 man
Thanks George. I bought a refurbed AFM from Paul Smith and it has hardly got any better... :sadface:
That same AFM used to easily pass 400 miles per tank even when it had the 3.2L engine attached [8D]
Adjust the right foot Simon
Suffolk944
Moderator
(On a serious note, I am guessing that a turbo driven off-boost is acting like a regular 2.5L car and hence more economical, hence the questions about what speed the boost is cutting in at, non?)
craiginuk
ORIGINAL: Suffolk944
Max 70 mph ? Sorry I don't understand ?????[8D][]
Sadly a court appearance is scheduled for end August so am taking it very slow for the next 3 years at least
craiginuk
ORIGINAL: zcacogp
Maybe I have found the one area where Turbo's are better than S2's - they are more economical! I reckon on between 350 and 420 miles from a tank on my S2, with varied driving. Best ever was about 460, on a long run in France. Some of you boys seem to be bettering that average.
Yep I was wondering about this. I was off boost most of the time. But was wondering if dropping a gear and getting on to boost would be more efficient or less?
George Elliott
Simon, you should have bought it complete with engine [
944 man
ORIGINAL: Diver944
ORIGINAL: 944 man
Adjust the right foot Simonor stop driving in the city
I had suspected that it was my driving style...
It can surely only be less efficient; on boost means more power as a result of greater cylinder filling and hence more fuel usage.ORIGINAL: craiginuk
ORIGINAL: zcacogp
More clever people will be along soon to confirm or deny this .... [&:]
