944 Turbo SE - thoughts, please...
- Thread starter pse_SC
chrisg
I've had a 1988 Non-Silver Rose Turbo S for many years now - know a few bits about keep them going.
As far as I know the the later Turbo SE's were very similar if not identical in spec to the original Turbo S (Silver Rose) specs, although happy to be corrected. Feel free to ring me sometime for a chat 07540 193874,
Chris
Suffolk944
Moderator
Nothing specific to look out for on late 250 models other than the usual 944 corrosion points. There is a school of thought that days that late cars are more prone to these issues than earlier ones so worth checking. My own car is currently at the body shop having the bottom of it's front wings attended to but an internal inspection of the sills has shown them to be in very good nick indeed, so it is very much a question of each car having different levels of bodywork issues.
scam75
Well-known member
M030 became an option in 89. Gearbox with hardened 1st and 2nd gears, oil cooler loop and LSD stayed standard. I believe the only difference between a turbo s and a M030 specced late turbo is the lightened windscreen. Also all turbo s had no sunroof and most 89 on had a sunroof.
I have a 90 turbo with CS wheels and bridge spoiler as standard. Also no sunroof. Also was 1st 90 model off the production line. Much rarer than one of those turbo s!! [
Stuart
944 man
1989 Model Year Turbos came with 7" & 9" forged Fuchs wheels. 1990MY Turbos came with 928GT-derived cast 7.5" & 9" Design 90s. They all had larger 928S4-derived brake calipers, in common with M030 optioned cars, but they did not share the dampers, bushes, ARBs or other parts that M030 included unless M030 was selected. The AOR transaxle was common to the M758 car
John Sims
PCGB Admin
blade7 said:.... 91 did get the bridge spoiler that looks miles better though.
or not. [8|]
blade7
Well-known member
John Sims said:blade7 said:.... 91 did get the bridge spoiler that looks miles better though.
or not. [8|]
[8|]
Ex Skyline
944 man said:The 1989MY> 250bhp model was called '944 Turbo'. Definitely not 'Turbo SE'. The Turbo SE (Actually Turbo with Special Equipment) was PCGBs name for the 1988 M758 'Turbo S'. The model name was down to the concessionaire, which is why Sonauto in France called it, rather more evocatively 'Turbo Cup'.
Simon to the rescue!! As usual.....[
944 man
Sifly said:Some very early 250's (1988) got the M030 suspension and forged alloys from the silver rose with a polished type finish. From around 1989 the cars came with D90 cast alloys which are heavier but painted so easier to look after.
This isnt really accurate. See my post above yours.
