nicksonmsport
just thought I would put up a list of what I have available for sale, the more sought after parts etc, I have much more of the run of the mill stuff if you need anything else. just email me info@nicksonmotorsport.co.uk
Porsche 944 turbo bodyshell, with logbook, rust free, new outer sills and lower rear 1/4s, harness points in shell, seat rails in shell, extinguisher mounts In shell, interior sound matt and seam sealer removed, full weld in cage can be fitted to spec
I can also supply Porsche 924/944 weld in rollcage kits to your spec if needed, or a bolt in cage to your spec, made to spec using bodyshell as a jig for perfect fit
azev deep dish early offset wheels in vgc with centre caps, 17x10j, 17x8.5j et15 all round
d90 wheels, 7 and 8j
m030 front brake discs used in vgc
Porsche script door handles /complete lock set with key
turbo ecu's, std chips, or can supply with chips for more power (can sell chips seperatley)
turbo front brake ducts
front bumper mounts, s2/turbo, as new !! vgc
working digital clock
good leather gear gaitor and gearstick complete
turbo afm, turbo throttle body, turbo inlet manifold adapted for extra turbo clearance (can also run stock turbo)
turbo crossover pipe
turbo bellhousing
m030 21mm rear anti roll bar, 3 hole, 944 turbo cup, with poly bushes
968 clubsport steering wheel, with Porsche crest embossed in centre vgc, early 911 boss to suit
m030 front brake calipers, refurbed (928 s4, 968cs, 944 turbo/s2 m030)
turbo dash clocks
turbo non lsd gearbox / torque tube
lux dansk stainless exhaust system dp back
turbo complete cylinder head and cam cover
turbo engine loom
turbo exhaust manifolds
turbo front crossmember
turbo oil cooler housing/oil filter housing with pressure switch and sender
smoothed rear bumper ready for paint
as new rear bumper trim with all fixings vgc!
turbo flywheel and clutch cover
as new turbo oil cooler (nos)
as new unfitted turbo radiator (nos)
s2 exhaust manifolds
s2 engine loom
turbo/s2 rear valence with good fixings
turbo/s2 front wishbones good
turbo torsion bars
turbo driveshafts
turbo crank sensors on bracket
turbo steering shaft no play
turbo clutch master and slave cyls
non a/c alternator bracket
turbo ignition leads set
all interior switches/fuses and relays available
lux wishbones
email me for pricing info@nicksonmotorsport.co.uk
turbo bellhousing
turbo dash clocks
turbo engine loom
s2 engine loom
turbo torsion bars
turbo driveshafts
lux wishbones
