Spongebob
I have an issue with my 1986 Turbo. Up until a couple of weeks ago the car has been driving beautifully but recently it has developed a major issue under hard acceleration.
Car starts on the button and under 'normal' driving behaves beautifully. It pulls cleanly and has been 100% reliable. The issue that has recently come up is under full throttle acceleration. Revs pick up to about 3k rpm and then it's as if you have driven in to a wall. It will then judder and then pop (sounds to be in the exhaust) and then clear itself letting out huge clouds of white smoke which rapidly clear and then it revs cleanly. It does this in every gear. It feels like a huge hole in the power band between 3 and 4k revs.
More gentle use of the throttle allows it to rev cleanly and freely to the red line in all gears and there is no evidence of smoking or hesitation under throttle. It's literally under full boost we have the issue and first happened when flooring the throttle to overtake an HGV.
I can't see anything obvious loose or missing under the bonnet, it is using no oil or fluids and as i say off full throttle drives fantastically. It is certainly a new issue as up to a couple of weeks ago it was a super fast beast on all throttle positions.
The car is fitted with Augment ECU, electronic boost control, up-rated fuel regulator and dual port wastegate. Until the recent problem it has behaved beautifully and is a very fast car.
Any ideas welcomed?
Any ideas welcomed?
