Thankfully for now my work on the s2 has finished, this months project was was to remove all the sound proofing from the rear of the car and replace the rear carpets with something much lighter, this was a task and a half especially with the front seats not being able to move forward out the way and then removing all the glue from the sound proofing,
Once this was complete i then replaced the rear carpet with a much lighter product purchased from flebay,i then fitted the new harness i had to the passenger seat and the went on to make a harness bar which i could fix between the hoop of the rear cage which i put in last year, once i obtained the correct tubing i then welded two brackets on each end so i could secure it to the cage....( inside finished )
Then decided after overhauling the brakes late last year with new discs, yellow EBC pads and racing fluid they would benefit from some proper cooling, to achieve this i wanted to replace the front bumper driving lamps with air ducts. Once i found the ducts i could work with i then trimmed them to fit, added mesh to stop any debris going down the pipes and then painted...next was to strip out the driving lamps and then fit the new ducts along with the correct air pipes to brakes... the only thing that was bugging me was that i had no side lights and after reading suggestions on this forum i decided to replace the front indicators with clear ones and use the unused half as a side light, so i move the wires for the side lamps up behind the indicators and drilled a hole in the unused side of each indicator which then aloud me to fix the side lamp in and then earth it, the only thing i wasn't happy about having clear lenses on the front because there were no other clear lenses any where else on car and i didn't really want to change any other lights as i quite like the orange indicators on these cars...what could i do? ah ha, i remembered seeing some orange indicator repair tape in my local motorist discount shop so nipped down there and made a purchase, i then applied the tape over the indicator part of the lens which went on very neatly and hey presto i now have a side light and an orange indicator which matches the other indicators on the car ...to finish i then splashed out and had i new cat 1 alarm fitted to replace the 10 year old system which had stopped making any noise... project finished....
So i thought... until i purchased a short shifter from flebay due to seeing the link on this forum, but anyhow that's another story already listed on here so i wont go over that again.
