944 s2 - intermittent power loss
5lab
So, had this happen to me twice now, any clues as to what it is??
car starts normally, and runs/pulls fine. after driving swiftly, right round a small roundabout at ~20mph, with my foot planted at the end, the car loses all power, and remains that way until (I think) hard braking.
The 'loss of power' is wierd. The car just seems to have no go in any gear, and some of the time is very hesitenty - as if its only firing on 3 pots (although stopping the car and revving it, it sounds fine - just when going along its lacking power). It has about enough power to get to/hold 50mph, but won't go any quicker.
When the situation resolves itself its absolutely fine.
This has happened twice, on cool (but not cold), damp mornings. I thought it could be HT leads, so gave them a quick check and sprayed some wd40 over them but to no avail. I think if it was ht leads the problem wouldn't come/go so quickly (it really is absolutely fine.. 30% power.. absolutely fine). I also think that if it was just missing on one pot, The car would have more power (I had a spark plug blow up on an old volvo years ago, and that would still comfortably hold 70mph all the way home (but drank a lot of fuel in doing so).
second thought is it could be something near a fuel line that the left-hand g-forces are blocking, and the hard braking is unblocking?? but I don't know what it might be
final thought is there could be something that's just lose. I thought about a bad earthshort but all the gauges look fine for the duration - I think if something was shorting the dash would also lose power??
any tips gladly appreciated :)
Hugh
Take the distributor cap off and dry it out. It will probably have moisture in it. Also check the arm and cap as they wear quite quickly on them and also get crusty around the contacts.
Alasdair
IS it just coincidence it's always happened round a roundabout?
Seems to me something must be loose and the extra G force of cornering is moving out of position
I had something similar to this on my first car. Old escort mk1. Turned out to be an exposed join one of the low tension wires to the coil earthing on the body during spirited left handed corners!
thanks. well, despite as much provocation as I could give it, I couldn't get the fault to re-occur on a 250mile drive over the weekend, so I guess its fixed for now...
£5 says it'll re-appear with a vengance at the ring over the weekend..
Might be worth getting a new DME relay just in case this is signs of the old one packing up. Also check the multiplug behind the engine ( assuming S2 is same as turbo) for any signs of corrosion or being loose. There are many possibilities but I'd eliminate these first.
Pete
