Goodoldmick
Hello please can you help?
I've got a Porsche 944 S2. It's only done 70 (seventy) miles since it was last MOT tested in June 2009. I've decided to sell it because I don't use it so took it for an MOT last week. I took it to the same MOT place that passed it last time but this time it failed because of the hand brake not being efficient and also out of balance.
I took it home and adjusted the shoes through the hole in the disc until each one locked then just backed it off so the disc turned. I pulled the hand brake on one notch and tried to turn the wheels (with the wheels now fitted again). They were solid, I couldn't budge them. Back to the MOT station "" failed again, same problem!
I couldn't believe it.
At this stage I would just mention that the whole braking system was renewed just 600 miles ago so all the discs and shoes are like new, for this reason I hadn't actually removed the discs to see if any of the mechanism had seized up because after all it was locking the wheels. I now removed both discs and made sure everything was moving freely in the linkages which they were. I set everything up again and went back to the MOT station "" failed again, same problem.
It seemed that the pads just weren't gripping the discs. Ah, I know what it will be I thought, the new discs may be too smooth for the pads to grip (even though they had passed on the previous MOT test). I took the discs off once again and sure enough the contact surface was lovely and smooth and shiny. I made a good job of roughing up the surface of both the shoes and the metal surface where they meet and reassembled the whole thing. I wound the adjuster nut at the hand brake lever right to the end as I had done before, then adjusted the shoes through the hole with a screwdriver until both wheels were just free of locking up. I then took up any play at the lever end by winding down the adjuster nut, pulled the lever up to notch one and tried to turn the wheels. They were solid. I went back to the MOT station again full of confidence "" it failed again, same problem.
Can anyone please tell me if this is a know gremlin with these great cars and what I can do about it. There is something familiar to me about this story. Three months ago I took an old Volvo estate to this place and they failed it on the same thing but the front wheels. I did a very similar thing and took it apart three times to make sure the pistons were free and not binding and each time they failed it again and the imbalance was the same side as the Porsche. I ended up scrapping the car. It makes me wonder if it is their rolling road that is at fault but surely not, they can't fail everybody with faulty brakes must just be a coincidence.
Any help would be greatly appreciated as I want to get it sorted and sell the car although I will be very sad to see it go [
Best regards
Mike Nettleship
Rotherham UK
Best regards
Mike Nettleship
Rotherham UK
