944 not starting
- Thread starter pitzey
PSH
You said a lot of work has been done by the specialist but don't say what? Go through what they have done, the fault most likely lays there somewhere if the car was running fine before.. Did you have a new dizzy cap and rotor arm fitted? If so remove the dizzy cap to make sure the rotor arm screw hasn't come loose, your symptoms could be this.
Pete
jonnyporsche
