944 lower arm
- Thread starter andyslade
pauljmcnulty
I got the strap from a car my indie had in, any of the used spares dealers should have one.
Peter Empson
James_G
ORIGINAL: andyslade
The balljoint on the offside front wishbone of my 88 944 2.5 lux needs replacing.
Do i still have to buy a complete arm?
Anyone got one?
Also i need a petrol tank strap if anyone has got one of them as well?
Andrew.
Andrew, I got rebuilt arms from Hartech and I was very impressed with the quality and 6k miles on and I never even think about them. I fitted them myself (search for the post, it was less than a year ago) and it's not a difficult job if you're handy with the spanners.
I chose to do both arms as I figured that after 145k miles while only one was making a noise, the other was probably passed its best too. But you may not think that's necessary depending on the mileage of your own car.
FWIW, my nearside was the one making all the noise, my thinking being that it had taken more abuse from potholes than the other side.
pauljmcnulty
ORIGINAL: Peter Empson
Sorry for going OT, but is your car back on the road yet Paul? If so was it a simple fix?
[&o][&o][&o]
We're in that grey area between "I heard a noise", and "there's a few areas that need attending to but none stands out as the cause".
It's great that my indie take the time to drive the car over the weekend so they can try to pinpoint the problem. I'm trying to avoid going down the route of replacing parts at random until we find an intermittent fault. What's interesting is that they've diagnosed plenty of parts that are worn, and could be causing a few odd noises, but are years away from replacing on a car that only does a few thousand gently-driven miles per year. [8|]
Peter Empson
John Sims
PCGB Admin
ORIGINAL: pauljmcnulty
..... on a car that only does a few thousand gently-driven miles per year. [8|]
So you should be thrashing it then? [8|]
Check your Lux carefully. If it's an early one, it will have steel wishbones and the balljoints are seperate units - easy to buy, and easy to change (they bolt on and off).
Later Lux's (I think), and the turbo and S2 models have the alloy wishbones which need a specialist to change the balljoints on. I'm not sure when they swapped over - '88 may put it in the later category.
tr7v8
88 will deffo be the later one the change date is the 85 1/2 one. Even the alloy arms have different versions, short & long, changed around very early 87 for ABS.ORIGINAL: zcacogp
Andrew,
sawood12
