Hello Everyone,
I just come back to the forum after probably 2 years away. Unfortunately during this time my 944 which for 3 years was my daily drive has only been used on occasional weekends due to a change of job.
Anyway it was likely to fail its MOT due to rusty sills and fuel lines so I had to decide what to do. For now I have taken it off the road and its getting some TLC. The plan is to use it probably once a week for the commute to work and then to do some track days with it.
It's away this week having new sills and some paint. Then next week I have access to a ramp and a week off work so I am going to replace the fuel lines plus a list of other things whilst I have the opportunity.
The list includes replacing the clutch which was suffering from lots of lash in stop start traffic probably from a worn doughnut. According to the stack of paper work I have for the car it appears to still be on its original clutch after 190,000miles. I was wondering if other people who have changed their clutch, release bearing, and press plate.....
1. Had the flywheel refaced or found they had to replace it?
2. Changed the rear oil seal at the sametime?
3. Changed the pilot bearing?
4. Changed the release lever needle bearings?
5. Changed the fly wheel and/or pressure plate retaining bolts?
Also does anybody around either Cambridge or North Staffordshire area happen to have an alignment tool which I could borrow for the week?
The other job on the list for next week is to investigate why the gear shift has become so stiff and vague. If I can solve this then the wife says she will try it on the track too.
Thank you in advance for your help.
