Hi,
I drove the S2 home from work about 35 miles with no apparent problems, then while ticking over while I opened the garage door the temperature rocketed. The fans had already cut in but to no avail. There was some coolant that looked quite oily dripping off the back of the undertray. The following day I pulled the plugs out and did a compression test with each cylinder around 165-170 PSI which would tend to indicate the head gasket was OK, topped up the coolant which took about 4 litres and started her up. There didn't seem to be any pressurising of the cooling system but the drip started again. Is there some sort of oil/water matrix or separator in the system which could be the cause or possibly the water pump?
